Old 12-03-2024, 11:43 PM   #1
Antoine86
What models is the JCB diagnostic tool used for?
JCB diagnostic tools are specifically designed for use with a wide range of JCB equipment and machinery. It is compatible with many of the company's machines, covering a range of construction, agricultural and industrial models. Here is a breakdown of the JCB model types that diagnostic tools typically support:
1. JCB Excavators
- Mini Excavators: Models such as the JCB 8008 CTS, 8014 CTS, 8020 8045 ZTS.
- Tracked Excavators: JCB models such as JS130, JS145, JS160, JS220, JS300 and larger tracked excavators.
- Wheeled Excavators: JCB models such as 403, 417, 467.
2. JCB Loaders
- Wheel Loaders: The diagnostic tool supports a range of JCB wheel loaders (models 407, 409, 427, 437 and 457).
- Telescopic Handlers: This tool works with models such as JCB 525-60, 531-70, 535-95, 540-170, 560-80.
- Articulated Loaders: For example, JCB 411, 417, and 427 models
3. JCB Backhoe Loaders
- This diagnostic tool is available for Backhoe Loader models such as JCB 3CX, 4CX, JCB 5CX.
4. JCB Skid Steer Loaders
- This tool supports JCB's skid steer loader range which includes models such as JCB 180, 200, 220, etc.
5. JCB Tractor Loaders
- Models such as JCB 3C and JCB 4CX are compatible with the diagnostic tool.
6. JCB Agricultural Equipment
- JCB Fastrac Tractors: This tool can diagnose and program various models such as JCB Fastrac 155, 165 and 4000 series tractors.
– JCB 4220 and other agricultural machines are also supported.
7. JCB Compaction Equipment
- Includes models such as JCB VM-130 and other vibratory rollers.
8. JCB Generators and Other Equipment
- The JCB diagnostic tool can be used for diagnostic tasks on generating equipment and other machinery in the JCB fleet, including mobile generators and small utility machines.
Key functions supported by the tool
JCB's diagnostic tool provides key diagnostic functions for a wide range of capabilities of these machines, including: For example:
– Read and clear Diagnostic Trouble Codes (DTCs).
- Real-time monitoring of vehicle sensors and system performance.
- Program and adjust modules and update or configure machine parameters.
- Perform system tests to ensure all vehicle systems are functioning properly.
- Perform calibrations of components such as pumps, sensors and actuators.
Conclusion The
JCB diagnostic tool is versatile and supports a wide range of JCB models in the construction, agriculture and industrial sectors. If you have a particular JCB model in mind, it's a good idea to check the compatibility of your tool with that model, especially on newer or more specialist machines.
Antoine86 is offline   Reply With Quote
