Old 12-02-2024, 04:01 PM   #5
spinjockey
So the part numbers have changed from the diagram but pelican is good about cross referencing. Here are the part numbers and cost:
Carrier 996-521-505-02-OEM $82.25
Under seat Floor Mat (Mesh Support) 996-521-507-02-OEM $58.00
Foam Seat Cushion 996-521-571-00-OEM $194.75
So total price for me was $335 which is a bit steep but I had to replace the cushion as it had lost all integrity. I also strategically applied two $20 discounts and free shipping so my cost was $40 less. I think if you only have to replace the mesh support then it’s totally cost effective to do this repair before the cushion or the carrier lose their integrity. The carrier was fine except the wire loom bracket was broken. Since I had to strip the whole thing down I decided to replace whatever was broken. If the leather had failed then I probably would have used an aftermarket cover from lseats because the OEM leather is not worth it.
spinjockey is online now   Reply With Quote
