Old 11-28-2024, 08:17 PM   #1
997_986
For the conversion check https://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm
For the coolant: it may be useful to use an endoscope to look into the cylinders via the spark plug holes in order to be able to narrow down the fault, otherwise you will not be able to avoid disassembly with such a fault pattern imho.
997_986 is offline   Reply With Quote
