Old 11-10-2024, 12:18 PM   #20
LoneWolfGal
LoneWolfGal's Avatar
Someone else can comment on that bolt, but I always have the engine mount bolted to the engine. If I need to attach to it, I run a nylon strap (scrap seat belt) around the frame of the mount and chain onto that.
I think I'll follow your lead and bolt the engine-mounting bracket to the engine before installing it. Thanks for the idea. In any case, there's a good chance I'll end up at least replacing the motor mount's bushing, since rubber deteriorates over time. While I'm at it, I might as well also replace the manual transmission's mounts, for the same reason. I want my 986 to be as vibration-free as possible. I once rode in one that almost vibrated the fillings out of my teeth.
7 pm addition: After reading about the travails of pressing a new rubber bushing into an existing engine mount, I think I'll just save time and grief by buying a whole new mount with bushing already installed, seeing as how they're fairly reasonably priced.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
