Old 11-08-2024, 09:28 PM   #4
BoxsterInTheSun
Originally Posted by Deserion View Post
That looks sort of like the bolt on the end of the reverse lever inside the transmission.
The fill plug for the 5-speed is in the left-side differential cover, a standard Allen socket and not torx.
Actually I wonder if I've just filled the crankcase from higher up...maybe draining it from the drain plug again and refilling from the correct hole is all I need to do?
BoxsterInTheSun is offline   Reply With Quote
