Old 10-31-2024, 04:40 AM   #3
PLP
PLP's Avatar
In my defense, it's only 420A.
It is always 5 o'clock somewhere...
As for the LEDs
Are you asking for a plain swap? Plug and Play like setup?
Then you can let it rest. There is no good LED chip that would relatively good mimic halogen filament in light distribution.
Yes, on paper the light source is much more intense and bright. But the reflector is unable to distribute the light properly. As a result you get hot spots, cold spots, glare... Some parts of the road will be well lit, while others will be dim.
The only proper way is to perform a LED projector retrofit/swap.
Or, if you must, do HID.
HID, as opposed to LED, is concentrated light source (small spot, like filament and with almost 360 degree of light, minus the electrode). LED chips are placed on two sides on a piece of metal and LEDs have 120 degree light distribution. Hence, from both sides you get a total of 240 degree max, what means you get two sides of 60 degree each that is dim.
And that is the problem with LED, which is not for HIDs.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is offline   Reply With Quote
