Old 10-28-2024, 07:10 PM   #153
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by flmont View Post
There is a rating for different strength's of concrete when they are poured, Talk to your concrete guy about your plan for a lift, they should recommend a 24 x 24 " pad or larger, that will be thicker, say 1' deeper than the rest of the floor that will ensure a strong base to bolt to Also consider a 4 post lift they are considered safer. Frank
They're also considered much more expensive. I know guys with both. The 2-post lifts are more affordable and acceptably safe, provided they're securely mounted. The guy who'll do the pour retired after 30 years of concrete work, but he likes to keep his hand in and supplement his retirement income. He'll make sure an adequate thickness of rebar-reinforced concrete is under the lift and threaded receivers for it are cast in the concrete. I appreciate your astute suggestions.
One thing at a time. The swap has priority.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
