Old 10-28-2024, 10:50 AM   #26
BoxsterInTheSun
You could do it at the fuse box.
Using a jumper wire with a spade on one end and a fuse tap on the other, insert the spade into the the unpowered side of fuse D5 (for the lighter), and use the fuse tap on a switched power fuse that can handle the additional load.
I came across a video on YouTube ( it has English subtitles ) that achieves the same thing mentioned here. Seems like a reasonable way to solve the problem: https://youtu.be/vgE-5sXXbAs?si=V-XY6EhGOBGKyQLT
BoxsterInTheSun is online now   Reply With Quote
