Old 10-23-2024, 04:23 PM   #1
elgyqc
elgyqc's Avatar
Originally Posted by LoneWolfGal View Post
Grant, I understand you installed one of these after removing its seals, correct?
Yes. One only removes the outer (rear) seal. This resolves one of the problems with the original bearing... the seal leaking enough to wash the grease out of the bearing but not enough to allow oil back in. Fuller explanations are available elsewhere.
Grant
elgyqc is offline   Reply With Quote
