Old 10-23-2024, 12:48 PM   #126
JFP in PA
Originally Posted by LoneWolfGal View Post
This might be a naive question, but I have yet to come across an answer: Since double-row bearings are much more reliable than their single-row counterparts, can a single-row bearing and spacer be replaced with a double-row bearing?
No, not with the factory width dual row as the two IMS shafts were different and required different size bearings. LN does have a dual row hybrid replacement for the factory single row which uses offset ball placements to keep the overall size the same as the single row so it will fit the shaft correctly. This LN product does require some specialized tooling for the installation however.
