Old 10-23-2024, 06:37 AM   #12
theiceman
often the door actuator is just completely worn out and needs to be replaced, they are not expensive. You are driving a Porsche afterall, spend a few bucks to fix it.
As you can see in the below pic, the switch actuating cam plastic coating has worn away and the metal quickly destroys the switch. you can see someone has attempted to spray white grease in there to no avail.
theiceman is offline   Reply With Quote
