Originally Posted by seventythree
The key language in the actual policy is "All internally lubricated engine parts are covered if damaged by the Failure of an internally lubricated moving part." In essence, meaning that unless the engine problem was caused by failure of the oil pump, there is no coverage!
I'm not sure if you're interpreting that right. There is a list of several items identified as "internally lubricated" in another post, so this would mean that a failure caused by any of those parts would be covered. I think you're interpreting the sentence to mean that the failure has to be caused by the lubrication system (i.e. oil pump), which is not what it says. Am I missing something here?
