Old 10-17-2024, 05:54 AM   #10
Spannerhead
Originally Posted by Rob175 View Post
Just a suggestion......before you put everything back into the trunk I put paper towels down and drove the car up to temperature.......afterward I checked for leaks......once I verified all was dry I put everything back in and consider the problem solved.
Yep; that's exactly what I did. Went through two complete heat cycles; no leaks. I considered it fixed.
Yes, but, how old is the car..? Plastic gets brittle with age, and also with UV exposure..
It's a 2002.
Spannerhead is offline   Reply With Quote
