Thread: Oil temp sensor
Old 10-15-2024, 05:38 AM   #12
bbmidmi
I know this is an old thread.... But do you have any info on how to wire the sender to the gauge? I'm a newbie on wiring but want to install what you have outlined.
So I ordered from Pelican: 323-055-M82 (temp sender, I would advise against a sensor which intrudes deeper into the engine) and 310-012-M82 (VDO Gauge).
I spare you the detailled description how to route a cable from the engine to the dashboard (basically I zip tied the cable to the tube between the airbox and the throttle body and after that to the big cable which goes through the rubber grommet in the firewall, from there under the center console and voila)
I compared the readings on the VDO gauge vs. the reading on the Durametric and the readings are spot on within +/- 2% of the readings from the Durametric
Enjoy[/QUOTE]
bbmidmi is offline   Reply With Quote
