Old 10-15-2024, 05:11 AM   #1
Spannerhead
Originally Posted by theWalkinator View Post
I just replaced water pump and thermostat, while doing coolant flushing, I over filled distilled water and water dripped down in front of rear passenger side like you said, and water find a pathway somewhere.
The drain hose for the tank top area is the bottom of the 4 hoses that go through the bulkhead (the one without a hose clamp), and it drains into the wheel well area, but the outlet is more or less in line with the axle (if you remove the wheel, you can see it). Somewhat further back from where "my" car was dripping, but I suppose maybe it could have followed the chassis brace forward... I dunno. I'm not too concerned anymore since the issue seems to have been fixed.
Spannerhead is offline   Reply With Quote
