Old 10-14-2024, 06:26 PM   #20
theWalkinator
I just replaced water pump and thermostat, while doing coolant flushing, I over filled distilled water and water dripped down in front of rear passenger side like you said, and water find a pathway somewhere.
There are 4 hoses going to expansion tank through a bulkhead and hoses are clamped to the bulkhead on both side, so that might be another source of leaks. If you have a coolant system pressure tester kit you can test pressure and see where the leaks is, you can rent one from you local auto part stores.
theWalkinator is offline   Reply With Quote
