Old 10-09-2024, 08:04 AM   #2
986lp
Does the engine run better when the MAF is disconnected? If so you could have a failing MAF. It sounds like you should chase down an intake leak, though. I recommend that you pick up a smoke machine (or DIY it), smoke the intake, and see where the smoke is escaping.
Those cam values aren’t great, but my engine is at -8.25 and -6.25 (I’ll be replacing the pads soon) and has no check engine lights and should pass smog.
986lp is offline   Reply With Quote
