Old 10-08-2024, 11:25 AM   #12
elgyqc
elgyqc's Avatar
Originally Posted by Newsguy View Post
Two questions:
1. You didn't use the hoist point by the throttle body?
2. Did you find an engine stand adapter for the M96, and if so, for under $700?
1. My friend Newart hung the whole engine by that little bracket near the throttle body, for a short period of time... but I only have used it as a backup to some other means. With another attachment point on the front of the engine, so it is only carrying half the weight, maybe... but it would make me nervous.
2. I use a standard adjustable adapter which works fine unless you want to split the crankcase halves, in that case you need the $pecial adapter. I was even able to change the IMS bearing with the standard adapter. When I split the crankcase on my broken 3.2 engine I did it on a pallet on the floor.
Grant
elgyqc is offline   Reply With Quote
