Old 10-04-2024, 06:44 PM   #12
Homeoboxter
A less sophisticated but simpler test is to pour about a quart of water into the trunk below the coolant reservoir. You will need to clean up that mess anyway. Then you just follow the route. If you see the water accumulate at the same places where the coolant did before, you can be almost 100 percent sure you have only one source of a leak. Good luck!
