Old 10-02-2024, 11:11 AM   #11
JFP in PA
Originally Posted by LoneWolfGal View Post
I'm giving Pedro's technoFix DOF another look.
From Pedro's site, describing his product: "[O]ur oil supply to the DOF uses oil which has passed through the filter and then through the cooler, before it goes onto the IMS bearing. ... This oil feed is supplied by the factory, so there is no drilling or tapping on the engine, simply screwing on a (supplied) adapter."
https://pedrosgarage.com/site-4/dof-info.html
If it's true that cool, filtered oil lubricates the bearing then Pedro's technoFIX is equivalent to LN's Solution for less than half the cost. The price for the technoFIX is $800, which doesn't include the bearing, $50 for single row or $100 for the double. (At this point I don't know which one my new engine has. I'll need a bearing extractor and the doohickeys to lock the cam chains and release the tensioner before I can find out.)
I emailed Pedro and asked for a better description and/or photo of the aforementioned screw-on adapter for the oil feed. The other end of the oil line is connected to the flange, like LN's Solution.
It is your car and your money, but both statements are wrong, the oil feed for the DOF comes from the cylinder head, one of the hottest and dirtiest sources of oil in the engine, the Solution takes it from the oil filter area, which is just after the oil cooler and after the oil has just been filtered. It isn't even remotely close to what the Solution is
