Old 10-01-2024, 04:56 PM   #2
LoneWolfGal
LoneWolfGal's Avatar
Jake doesn't make or sell parts, but he does own the patent(s) rights to the Solution; the actual product is made by LN Engineering, Jake just takes a cut off the top on every sale, which is his right as he spent all the design and testing to destruction time of the various iterations of the Solution before settling on the final design and then patenting it.
Interesting. In that case, if all references to Jake are replaced with LN Engineering, I stand by what I said about price gouging. After all, we're not discussing an interocitor here, just a relatively common bearing with a direct oil feed.
As for the price, you get a lot of beautifully engineered stuff in the kit, all of proven to work; and what no one seems to take into account is that it will never need replacing, unlike every other IMS retrofits, including the LN units. So it is once and done as long as the engine lives. And even then it could be transferred to another engine. We have a customer that got a single row Solution at around 60K miles; the car is now approaching 200K miles and it is still in there doing its thing. The only thing we ever replaced on it was the braided SS hose that carries the oil from the filter housing to the Solution after a tire kicked up something the smacked it pretty hard, and even then, it wasn't leaking, just ugly; so we replaced the line as preventative maintenance.
Doggone it, JFP, you're making this decision really tough! If cost were no object I would just fork over the $1900, because the 39K M96 deserves the very best. But alas, cost is an object. And then there's the uncomfortable feeling that cost-wise I'd be getting fleeced by LN, which certainly factors in. The second point falls under "general principles."
But it sure would be nice to never have to worry about the IMS again... Doggone it, JFP!
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
