Old 10-01-2024, 10:32 AM   #10
LoneWolfGal
LoneWolfGal's Avatar
To answer your question, Jake Raby actually ran an IMS Solution for a prolonged period with the oil feed line disconnected during the system development and testing; Jake noted that the IMS Solution survived this without issue on just the oil mist inside the engine. But knowing that Jake is a decided "belt and suspenders" type engineer, he kept the oil feed line, which delivers a slow, controlled amount of oil, because he knew that a lot of the Solutions would end up in track cars where heat build up in the bearing is more severe. He also wanted this product to be a "life of the engine" answer to the original bearing's short comings.
Having had the opportunity to see IMS Solutions after hours of track time on dedicated tract rat cars, I think he did the right thing; these Solutions looked like they just came out of the box.
JFP, I don't doubt that you are absolutely correct about the Solution. I always listen carefully to the Big Dog. Which is not to say that Jake Raby isn't price gouging. As I said to another forum member, if he'd priced the IMS Solution at $999 it would probably sell like hotcakes, and I would undoubtedly convince myself to buy it. But pricing it at almost two grand — that's out of line, if you ask me. That said, your point that a Porsche is an expensive car to own is well taken. I guess it could be worse, though. I could be working on a Bugatti Veyron.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
