Old 09-30-2024, 01:15 PM   #4
tcoradeschi
Registered Member
Originally Posted by Nickanator8 View Post
It refused to slide into its housing. After I broke it I fully disassembled everything so when the replacement part comes in I can just get to the install process. Even with the knuckle removed and just the control arm to deal with the bushing just does not want to go into the place it came out of.
My confusion is mostly steming from the fact that every guide or instruction video seems to say, "Just put it in" but mine simply didn't fit.
I guess I'm just unlucky?
Maybe a defective part. The taper on the ball joint and the taper in the hub are identical (well, one is male and one is female).
tcoradeschi is offline   Reply With Quote
