Old 09-24-2024, 12:19 AM   #1
Antoine86
How to Check Engine Oil Level in a Porsche Using a PIWIS Tester
To accurately check the oil level in your Porsche, use a PIWIS Tester, which provides greater accuracy than the standard instrument cluster method. This process is essential after every oil change to determine how much oil needs to be added to achieve optimal levels.
Steps:
1. Plug in the piwis 3 and turn the ignition on.
2. Start the diagnostic program and select the vehicle.
3. In the overview, go to DME control unit and press [F12] to continue.
4. Go to the "Maintenance/Repair" menu and press [F12] again.
5. Select the Oil Fill function and press [F12].
6. Start the engine and run until the oil temperature reaches 90°C, accelerating if necessary.
7. The oil level measurement will start automatically as soon as temperature is reached.
8. Stop the engine.
9. Fill the PIWIS Tester II with the specified amount of oil.
10. Finally, remove the tester.
Antoine86 is offline   Reply With Quote
