Old 09-23-2024, 03:24 PM   #10
JFP in PA
Originally Posted by LoneWolfGal View Post
Wish you were here, because the IMS Solution's installation instructions made my hair stand on end. For example, by drilling and sawing, "cut a notch in the crank case for the pressurized oil line that feeds the IMS Solution." Yikes!
It really isn't all that bad; you need to set the Solution flange loosely in place, mark the line fitting location with a marker on the bellhousing flange, then using a couple of increasing drill sizes, drill out where the fitting will sit, then use a metal saw to saw into the final hole you drilled out. A little bit of filing to break all the sharp edges from the drill and cutting and presto, a perfect slot for the flange's fittling to drop into, the slot being a little large is fine. Only takes a few min. to do.
