Thread: bonnet opening
Old 09-23-2024, 03:57 AM   #2
PLP
PLP's Avatar
Originally Posted by joshua3mm View Post
I have 3.2 then I'm not 100% sure if it's this same or not.
If you can't find a cable when you remove the wheel arch , it's not visible then other option it's to remove light.
Wysłane z mojego M2101K9G przy użyciu Tapatalka
Czesc.
Did you open it?
There is a way - feed power via cigarette lighter. Ensure you are limiting voltage and current as otherwise you will blow the fuse.
If you use a battery charger, monitor the voltage as without the battery in, the charger may climb too high and fry your electronics.
Then release the hood, or frunk.
Or, when connecting the battery via the red pull tab in the fuse box - pull the tab all the way out and insert the key into ignition. Car freaks out as it thinks it is being stolen.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is offline   Reply With Quote
