Old 09-20-2024, 02:33 PM   #1
JFP in PA
Originally Posted by professorman View Post
I see some oil dampness on the right side of my engine. I think the lower boot bellow for my AOS is leaking.
Is that something that can be changed easily? Or does it require the entire AOS to be removed?
I don’t think I have a bad AOS. It was changed at the dealer 2 years, 15k miles ago. I have no symptoms of AOS failure.
2001 Boxster S
Yes, these boots can and do leak. If yours is leaking, yes you have to remove the AoS to get a it, and I would HIGHLY recommend replacing the AoS along with the boot, and ONLY USE THE FACTORY AoS, NEVER AN AFTERMARKET UNIT.
