Old 09-18-2024, 12:37 AM   #14
997_986
POSES recommends removing seat first
1. Remove switch -2- from the seat. Unscrew fastening screws -1-. Pull switch -2- upwards and remove forwards -arrow-.
2. Unscrew control unit -4- in conjunction with seat memory fastening screws -3-. Remove control unit -4- and fold it forwards. Pull out the plug -arrow- together from the control unit. Unclip the plugs starting from the right, natural, blue, black.
3. Plug connection -6, 7, 8- without control unit seat memory Pull apart the plugs underneath the seat -6- seat backrest adjuster, -7- lumbar support, -8- backrest and separate the cable ties for the cable.
4. Cable routing between seat cushion and seat frame. -A- Seat cushion -B- Switch -C- Cable Pull out the plugs one after the other through this opening.
997_986 is offline   Reply With Quote
