Old 09-16-2024, 08:22 AM   #1
JFP in PA
Originally Posted by lurky View Post
Hi JFP
The error code is:
P0455 Powertrain - Evaporative Emission Control system leak detected
So far I have replaced the gas cap and the error still came back.
I also plan to replace spark plugs.
I'm considering replacing the Canister Purge Valve Solenoid
Is here a sensor that could be the culprit? And a hose?
You have been chasing your tail; P0455 indicates an electrical short at the EVAP canister purge valve, either the valve itself or the harness. You need to run short diagnostics on both before spending even more money swapping parts.
