Old 09-15-2024, 07:26 PM   #37
Danimal
I had the classic clattering in the back going over rough ground at low speeds. So I changed the rear trailing arms with the 987 TRW part listed in this thread. It is much cheaper than the corresponding 986 part from TRW.
I did it with the whole car up in the air using lift bars. Had no problem aligning the bolts, just had to push a little on the lower control arm. I used the existing bolts and torqued them to spec (118ft/lbs). I did not use loctite but sort of wished I did. Oh well.
Took it on two test drives and the clatter is gone. Still can’t figure out what was wrong with the olds ones. But glad the commotion is gone 👍
Another great fix from the forums in the books! 📕
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
