Thread: bonnet opening
Old 09-14-2024, 08:29 AM   #1
joshua3mm
I have 3.2 then I'm not 100% sure if it's this same or not.
If you can't find a cable when you remove the wheel arch , it's not visible then other option it's to remove light.
You don't need actual access to frunk to remove light.
You need a long flat piece of metal which you need to insert under your light and twist to one of the sides to release your headlight.
There was some video on internet as this lights where prone to be stolen very easy as they are on track and lock it's easy to be released.
Wysłane z mojego M2101K9G przy użyciu Tapatalka
joshua3mm is online now   Reply With Quote
