Thread: Crank No Start
Old 09-12-2024, 03:06 PM   #1
Deadly
00' Porsche Boxster 2.7L
Deadly's Avatar
Originally Posted by flaps35 View Post
Ok, so you've verified that the fuel pump relay is not getting energized to command the pump on. That's a good start. Stop throwing parts at it until you can narrow down the reason for the fuel pump not getting commanded to energize. Do you have a scan tool? First I'd want to scan for any codes, report back if there's any active codes.
I haven't scanned it in a while, but I will order an OBD2 scanner and get back to you with more information.
Is there a technical diagram of the immobilizer?
Basically I'm assuming that if the logic strings don't match up between the immobilizer and the key then the immobilizer sends a signal to various parts of the car preventing them from operating. I would like to take my multimeter and test if I'm getting an electrical signal from my immobilizer, (or perhaps even a lack of signal that SHOULD be there) thus preventing the car from starting. The immobilizer is complex, but it's not magic; I should be able to test it myself with a multimeter, I just don't know what or where I need to test on it.
Thank you.
O, Death... become my blade once more.
Deadly is offline   Reply With Quote
