Thread: Crank No Start
Old 09-12-2024, 12:38 PM   #1
flaps35
Ok, so you've verified that the fuel pump relay is not getting energized to command the pump on. That's a good start. Stop throwing parts at it until you can narrow down the reason for the fuel pump not getting commanded to energize. Do you have a scan tool? First I'd want to scan for any codes, report back if there's any active codes.
flaps35 is offline   Reply With Quote
