Old 09-12-2024, 11:16 AM   #2
JFP in PA
Originally Posted by OldMacTech View Post
Major voltage drop.
Every thing off, doors closed, no key, frunk light disconnected, interior lights disconnected, radio off.
Every 45 sec the voltage drops nearly 1/2v but after 15 secs returns to full voltage but a few volts less than before. Went from 12+v to under 9v in about 2 hours.
Almost has to be alarm? I’ve never had the alarm go off in the 5-6 yrs I’ve owned)
Also, one time I had rodent issues in the engine compartment but once fixed, no problem.
The alarm is fused (should be E1 or B8), so you should have seen that doing your fuse pull diagnostics.
