Old 11-17-2006, 06:28 AM   #4
blue2000s
Porscheectomy
Originally Posted by KronixSpeed
my only issue with them is that i think they will eventually burn the plastic infront of it. mine are getting yellow/burnt just with regular after market white blubs, which probably aren't even as strong as the hids 5000k. this is also over time that they are turning yellow/burnt, not like it happend right away. probably best to get a really good clear white blub for $50. i've seen piaa has a white clear xenon light, not sure the watts, but these are probably the best bet. i'm not talking about the piaa eurolights. look into why the screen turns yellow/burnt, before installing the hids.
whats really cool, is the original. the way that you can see the actual projector blub. the hid blub hides behind the screen and pretty much useless, better to just get a white blub.
I suspect you're having a yellowing problem because your aftermarket bulbs are running hotter than stock. Yellowing can come from either that or UV degradation of the plastic or both.
The HID upgrade system should actually run cooler than halogen bulbs and be less prone to yellowing.
