Old 09-08-2024, 06:58 AM   #15
10/10ths
"50 Years of 550 Spyder"
10/10ths's Avatar
First of all…
…Drive the darn thing.
Sitting around is the single worst thing for a vehicle.
If you really aren’t going to drive her, then definitely fill up with “Pure Gas” or “Rec Fuel.”
There is a web site, Google “Pure Gas”, that will show you pure gas stations around you. If you live near a body of water that attracts boaters, typically the gas stations near the boat launches sell pure gas.
Dump a bottle of a “PEA” fuel additive into your tank, fill up with pure gas, and drive around for about twenty miles to mix it all together and get it into the fuel injectors and cylinder walls.
The only fuel additives out there that have the PEA in amounts that work are “Driven Injector Defender” and “Carb Defender”, Chevron Techron MARINE, Gumout “Total Fuel System” and Redline Fuel system cleaner.
But you should really drive her.
Better to be driven into the ground, than to rust to death.
10/10ths is online now   Reply With Quote
