Old 08-27-2024, 11:39 PM   #1
abuislam
Sounds like you've covered a lot of the common issues. Since replacing the micro switch and pulling the relay didn't help, you might want to check the window motor or its connections. Sometimes, manual top operation changes can affect window operation. Also, inspect for any binding or obstructions in the window tracks. Hope this helps!
abuislam is offline   Reply With Quote
