Old 08-27-2024, 10:05 AM   #4
Gilles
First you have to open the bonnet..
Bigv twin996, before anything else, you have to open the bonnet..
I would suggest to supply a 12VDC power to the cigarette lighter plug, this will allow you to open the front compartment (this is way easier than fishing for the emergency cable..)
The 12VDC should be from an external battery as usually a battery charger will not have enough amps to open the frunk, good luck!.
