Old 08-24-2024, 01:21 PM   #4
Nick2508
Hi weegogs,
Good to hear that my P1502 fix is still helping people get their Y2K Boxster's working again!
It's strange that it seems to be specific to that model year - perhaps Porsche spotted an issue and re-engineered a component early in 2001?
As mentioned in my original www.renntech.org post, the P1502 limp mode issue was nothing to do with the:
- Throttle Body
- MAF sensor
- DME
- Wiring loom
I'm not convinced that it was a relay or battery issue either (although I changed both shortly afterwards).
I can't give a 100% guarantee, but my view is that the root cause was a worn and faulty ignition switch.
The electrical switch can be replaced for about £20-£30.
It's used by VAG on Audi, VW, Porsche and Skoda cars and the part number is 4A0905849B.
You don't need to pay Porsche prices for a genuine part, but I'd get an OEM part rather than one of the cheaper copies.
You don't need to change the ignition lock barrel, just the ignition switch.
I'd buy a couple if you plan to keep the car for a while.
I'm about to change the switch again (12 years later) as it's less 'clicky' and is starting to feel loose and worn out.
Cheers,
Nick.
Nick2508 is offline   Reply With Quote
