Old 08-20-2024, 05:08 AM   #10
elgyqc
elgyqc's Avatar
Originally Posted by elgyqc View Post
That is a possibility, now that I know how it works. There is another way to lubricate it via the steel blocking plate at the other (left) end of the bolt.
I did some experimenting along these lines with my old unit which is detailed in this thread.
https://rennlist.com/forums/boxster-and-boxster-s-986-forum/1411338-igntion-key-mechanism-issue-with-barrel-door-and-steering-lock.html
This was done with the unit out of the car, I can't visualise if it would be possible to drill a hole in the blocking plate to permit spraying oil in while it is still installed. If you do drill a hole do it somewhere around the edge where the spring won't be compromised.
Grant
