Old 08-14-2024, 09:03 AM   #1
JFP in PA
Originally Posted by Ben_Pal View Post
Thanks,
I think I have the right part, I was searching for a ring because the guy at the local bearing store said that usually a "wire" goes there to reduce vibrations.
It was included in the Pelican Parts IMS Bearing Retrofit Kit. I thought it was a retainer not the slip ring.
Ben
If you are even contemplating using the pelican retrofit on a dual row engine, I have one word of advice: DON"T. You would be replacing the known most durable IMS bearing with the one that has suffered the most failures.........
