Old 08-11-2024, 05:10 PM   #1
NiXBoX
Brake fluid replacement ?
I am following the 101 project guide for Boxster and am planning on replacing the brake fluid.
The reservoir currently contains the old brake fluid. Should I extract the old fluid from the reservoir first via suction pump and then fill it with new brake fluid and then proceed with the bleeding process per the guide?
I am concerned that if the reservoir is filled with the old fluid and I am replacing it with the new fluid using the power brake bleeder that the new fluid will just mix with the old and I don't have pure fluid replacement.
Appreciate the suggestions.
NiXBoX is offline   Reply With Quote
