Thread: Radio/Amplifier
Old 08-05-2024, 04:51 AM   #2
spinjockey
Do you have speakers in the door? If so then you have option 490 and yes you can buy an amplifier to plug and play. You will need an aftermarket wiring harness adapter because no radio is an exact match pin for pin. The early boxsters thru 02 also had switched and constant 12v reversed so a lot of people make the mistake of connecting the wires based on color matching to find out their clock settings aren’t retained in the radio.
You should also be able to look at the option sticker under the hood to verify.
spinjockey is offline   Reply With Quote
