Old 08-01-2024, 06:17 PM   #1
Frodo
Jack up each front wheel and spin it.
If you do this, just remember that there's a brake caliper behind that wheel. I mindlessly tried this years ago when I was hearing sounds from the right front of the car, suspicious of a bearing issue. Car jacked up, just stuck my index finger through a spoke opening and spun. Nearly took the end of my finger clean off
Lesson learned!
Unfortunately, nothing sounded weird when I did that. Nor did anything feel off when I did the 12/6 o'clock and 3/9 o'clock tests either. Couldn't find anything else (pebble in the brakes, etc)...so I got me a Sir bearing/hub tool set and replaced the bearing. The noise went away. Go figure..
