Old 07-31-2024, 06:32 AM   #3
KevinH1990
KevinH1990's Avatar
https://youtu.be/z4cB7HQDAvo
This link shows the process for removing the gauge cluster. I recommend that you remove the cluster and check to be sure that all of the connectors are seated properly. If I recall correctly, I've seen posts that suggest the connectors and associated wiring can fail with age.
