CASED CLOSED. I found the culprit - it was the connector to the window motor. Not a bad connector, just the mechanism that supposedly CLIP on the window motor, both sides are bad and I'll assume the vibration kept jarring it off the motor causing a bad connection.
Noting some zip ties and electrical tape could not fix. Had to do it twice because it came loose again after the initial fix.
Anyways, to all that asked & shared - much appreciated! This is a great forum of knowledgeable and helpful patrons.
Much appreciated.
