Old 07-29-2024, 07:54 PM   #1
martinef1963
2000 986 & 1972 914
martinef1963's Avatar
Passenger Side Window Won't Go Up?
Hey Gents,
I just finished replacing the alternator and was going to take my 2000 Boxstert out for a test drive and while my passenger side window was going down it stopped 2/3 of the way down and won't move???
I swapped the wiring on the switches to eliminate a bad switch, which didn't help. It's nighttime here in Miami and tomorrow will check the D1 fuse to see if I have continuity. I believe that not to be the problem because there is only one fuse to check for both windows - am I mistaken?
Is there a manual way to raise the window without damaging the window regulator? I plan on taking the door panel off and see if maybe a connection came loose?
Any words/direction in which to take would be appreciated.
martinef1963 is offline   Reply With Quote
