Old 07-29-2024, 07:31 PM   #12
paulb
Originally Posted by elgyqc View Post
The engine is under the car and ready to be installed, I was waiting for the arrival of my new PRG transmission mounts. Here they are ready to go.
I couldn't find the torque for these mounts so emailed Greg at PRG... 60 ft/lbs. He also mentioned a detail that might interest some of you who have these mounts.
"There is a crush sleeve, get the bolt tight, about 60lbs. The bolt torque has no relevance on the bushing preload. The bushings are set to a predetermined preload by the length of that sleeve. you could machine a longer or shorter crush sleeve if you wanted to try different settings "
Hi. I was wondering how these prg tranny mounts are doing. I’m considering them for my ‘04 S. Do you like/recommend them or would you go oem if you had to do it again?
paulb is offline   Reply With Quote
