Old 07-21-2024, 11:05 PM   #2
Homeoboxter
I have a couple shafts lying around in the garage, one has similar marks. I think it's factory since that surface in not in contact with anything, as you pointed it out. I assume you inspected the the inner surface of the engine halves and the oil pump housing with te bearing external where the IMS runs. I can see some discoloration on the shaft, or is it just reflection? PM me if you need a replacement.
