Originally Posted by Smallblock454
DME 7.2 is different to 7.8
Also the wiring of the M534 / M535 is different.
And M534 to M535 is also different.
Make shure that you have the correct wiring diagrams for exactly your model year and immo. Else you won't have luck.
So all the wiring checked out. I decided to go back to square one and put the old wiring back in. I have corrected my post above to confirm I have M534.
No lightning power sign now. Just brake fluid warning, as there not much in as I have swapped the ABS pump back.
